I just bought a 1997 Vulcan 800. The problem that I am having is that the right turn signal does not blink. The left turn signal blinks fine. Anyone know what would cause this?
Thanks in advance!
does your switch click at all when you slide it to the right like it is making contact? if yes, check your wiring. the wire connectors might have come unplugged.
Discussion Starter #3
Hmm, so if it's not clicking when I push it to the right then the switch is bad? If the switch checks out then where would I look to check for any undone plugs? Under the seat?
