1 - 4 of 4 Posts
ok the little ninja that could or is that the ex250 Line?
:oops: my little 1/2 liter 500 has got me singing the blues
my gas is leaking out of the" pilot screw "
why is this happen-in if kawasaki wanted my $2.50 gal. gas to be used as a drip cleaner for my starter they would have ran another hose right to the ground because thats where my gas is going ..
is this doing this because my float is out of whack .... help me
so my i can go riding to night with my bra off
AZ's Official Mechanic
do you mean your AIR/FUEL SCREW ??? (on the outside of the carb)
if so then i would pull the carb(s) and clean/check them. make sure your float level is correct and that the needle/seats are in good shape.make sure ALL your vent lines from/too the carbs are open/not pinched/burned shut etc.
good luck :wink:
Motorcycle Momma
plumper40d,
Welcome to the forum. Know the pain about gas....it went down a bit here...lowest is where I live at 1.79/g :lol:
You might also want to post your problem down on mechanics corner. There is a lot of mechanical experience here at your disposal.
Give what QKENUF4U said a try.
Heather
1 - 4 of 4 Posts
