that would be the first 250 that didn't need an adjustment on the first service I have heard of. every one I have done needed exhaust on 1 and intake on 2 adjusted.
Maybe I got that one in a million type bikes. Cant complain about that though. The hardest part about checking the clearance was getting that valve cover off. That was a pain in the @ss
burned valve seats, crispy fried valves.....tight valves, hard to no starting, loss of compression...
Take the spark plugs out to release the compression and use the kick starter (and your arm) to tap the engine into the right position.I didnt drain the coolant but I was about to because the coolant line goings into the engine right next to the cover and it was tough to slip it by the line but after about 2 hours of messing with it and taking the right side coil off it came off. What really made me made was the fact that when I went to put the cover back on it, the cover went back on like a hot knife through butter. Took about 2 seconds to get it back in place. And I am sure I got the measures right because after I checked it, I had one of the mechanics at work who worked on Harleys for many many years before and had done valve clearances a billion and one times recheck it just for that added comfort. He got the same readings I did. He kept hitting the starter button to turn the cams over for too long. He was getting so mad that he could get them in the right position until after the 20th try.
