1 - 4 of 4 Posts
Have been reading alot of info on here about noise from drive belt. I put a new rear tire on my 04 2000, adjusted belt to where it was before I took the tire off. went about 600 miles and developed a noise that sounds like its coming from trans. anyone have the specs on how tight the belt should be. I have read factory specs are way to tight. any info would be greatly appreciated. thanks
Forgot to grow up
I'm using factory specs with a new belt. The orig started to chirp after about 20,000 kms. If you are hearing "transmission noise" only under hard acceleration, you may be skipping the cogs.
2005 V2K
Using a belt tesion tool - 10lbs of force with 3/8" of flex
Just set mine up today, as I just changed the tires.
From the service manual:
Drive Belt Deflection (with 45 N, 4.5 kgf, 10 lb force)
Standard: 2.5 ~ 4.0 mm (0.10 ∼ 0.16 in.)
Drive Belt Deflection (with 45 N, 4.5 kgf, 10 lb force,
when installing new belt or engine remounted)
Standard: 2.5 mm (0.10 in.)
If the deflection is out of the specification, adjust it."
1 - 4 of 4 Posts
