1 - 2 of 2 Posts
does anybody any ideas why my vn800(2005) keeps running on one pot,for some reason the back pot keeps going down then after a while picks back up and runs on to both again,every thing as been checked,plugs,compresion is ok,coils checked,carb cleaned out and re-jetted with no joy.....
Machinist For Sale/Rent
Since it is fed with a single carb the problem is almost certainly fire issues. Either the coil is getting hot and going into no saturation phase or the wiring feeding the coil is damaged or loose. Take the coil off and inspect it carefully for cracks in the case, or swap it for the front coil and see if tour problem goes to the front Cylinder. No matter if everything has been checked, something was overlooked or passed the immediate test. Intermittent failures are tough to chase
1 - 2 of 2 Posts
