1 - 8 of 8 Posts
Hi, since a 6 months I bought a second-hand VN800 classic 1997 bike.
It's a very nice and handsome machine.
But I have two questions:
1) I don't have a user manual. Is it possible to find it on the web?
2) I have to choke even in summer to start ,and choke is needed for at least 2 or 3 km. This makes the bike a thirsty one.
For a Harley this seems normal but a Vulcan looks only like a Harley and uses modern technology, so I wonder if maybe something is wrong.
Once the motor is warm, it runs smootly New sparkplugs didn't solve the problem.
Thanks
Congrat's on the new ride. Buy some extra toothpaste to get the bug's out of your teeth.<BG> Now the question about the manual, get on ebay an hunt up vulcan's ,I was on there last night an they had plenty of new manuals for $20 or $21 bucks. Make sure it's a clymer's . It's much better than Hayne's. You might even call Beartooth if you want someone to order you one? hope this helps
re
is the bike stock? i don't run my choke that long even on the harley :lol:
check the carb and the fuel mix and don't ride it with the choke engaged
let it sit to warm up - in fact i like to keep it running with the throttle if possible and use the choke sparingly :wink:
Run a can or two of sea foam thru it , it help's clean out the carbon in the motor an also cleans out any tarnish on the inside of the carb.Then you can check the air filter (maybe replace?)The reason I mentioned the sea foam is because of the age of the bike an I don't know the maintence that's been done on it?? If you run the sea foam thru it you might want to think about changing the oil. I don't know for sure but some rider's talk about some of the carbon ending up in the oil. Sound 's like it cleans it up pretty good!!
· I miss you, Deron
I have to use the choke when I start mine up, even when it's warm. I usually start it and let it run while I get my gear on. By then I can tell from listening to it that it's warmed up, and I close the choke when I take off. I'm getting nearly 55mpg, so I don't think the warm up with choke is consuming all that much fuel.
Julie
· I miss you, Deron
Sorry for my ignorance, but what is sea foam? I did a Google search on it, but I couldn't find anything. Where do you get it?
If I understood well, my motor is dirty so I have to use the choke for long time and this makes my motor more dirty and so on...I shall try to ride without choke after a short warm up, even if it's running not smoothly. If this doesn't work, i'll try the method with the seafoam (or a special motorcleaner if I don't find any)
Thanks all for the help.
Greetings from a rainy Belgium (a small kingdom by the sea between France and Germany)
· Rebel Rider
Most 800's are cold natured. Mine gives a little sputter on take off even after riding a mile. This with the choke off. There is a carb adjustment you can make to stop this. Someone on the VROC group can tell you how it's done.
bluestringer
1 - 8 of 8 Posts
