1 - 10 of 10 Posts
Hello,
I'm working on a coworker's bike and I am desparate for help. It's a 1999 Vulcan 1500 Classic and it's leaking oil from the top of the rear cylinder. Easy fix, right? Wrong. I've got pretty much the whole thing torn apart, to drop the motor, with the exception of where the drive shaft bolts up to the engine. How is this removed and are there special tool required? I've searched and searched these forums and I can't see where this has been addressed before. Also, once the motor is removed, is there anything that I should be looking for or addressing while the motor's out? Any help that could be provided would be greatly appreciated.
Thanks,
Mike
Deeppurple52
There is a small pin that has to be pushed in to remove the shaft. Rotate shaft until it is visible, use small pick or nail, push in, pull off shaft. Samie, same to reinstall.
Thank you for the reponse. So, do I just peel back the rubber boot or do I need to unbolt the four socket head bolts that are holding on, what appears to be, the bearing retainer?
Thanks
Love my 1500!
If I remember, that pin has a spring behind it and will shoot across the room if your not ready!
Does anybody know if there is a right up on the process of removing the engine? I know the standard response is "Buy a manual" but I'm not willing to buy a book for a bike that isn't mine. I've searched and I've searched but I can't find the info that I need.
If you are doing the work for free.....then he should buy the manual. Standard procedure for me in removing the motor................remove the rear wheel. Unbolt the final drive case from the swingarm. Remove the swing arm. Peel back the boot and push in the pin and remove the driveshaft. Remove the tank, seat, all that crap. From here it is pretty straight forward. Nice to have someone holding the bike when you remove the motor. Oil filter gets in the way when it comes out on my bike, so removing that will help.
1 - 10 of 10 Posts
