1 - 6 of 6 Posts
Concerning the Nomad 1600 spark knock. --- Kawasaki states 95 octane minimum - tag under your seat. 95 is hard to find, 91 is what we have. I would like to indorse the PowerCommander V spark-knock fix-comments, and thank you all who have made them. A Baron V95 intake system was also installed. The stock pipes give good power and have an improved sound, they will stay. My Nomad has come alive. Ride Safe
95 is research octane # (or mechanical..cant remember which) the 91 is research + mechanical divided by two. R+M/2 at least it is down here.
FWIW, my 04 Nomad pinged terribly even on premium, after doing some research, I went with one heat range colder spark plugs, pretty much eliminated it. research showed the older Nomads came with the colder plugs, I couldn't find any changes that should have required a hotter plug. If the colder plug helps, then the hotter plug tip was causing it... Probably should have went 2 ranges colder. The oem plugs that came out were the blistered white look of too hot a plug instead of a normal tan color.
I also had to use throttle body/intake spray cleaner regularly. back side of throttle butterflys would be black, even before the plug change..
Discussion Starter #3
Thanks for your reply, interesting, glad a plug change is working for you. Are you using an NGK DPR7EA9 ? With stock NGK DPR6EA9 the PowerCommander keeps my burn correct. The Baron V95 BigAirKit (DennisKirk) allows my 08 Nomad to breath better. L side becomes bare cylinders, R side gets a K&N and there is a lot less plumbing involved. They work well together, not hard to do.
I sold the Nomad a while back, got too big and heavy. Have a Versys 1000 now along with an 1100 Shadow Ace Tourer.
I believe it was a 7 I went to, have to look them up to tell for sure. Back then Gas was heading towards $4/gal, I was not too wild about adding a power commander to throw extra fuel in to cool the combustion chamber,,, Took it and had a dyno run done in stock trim, fuel curve was almost flat, Mixture was pretty much perfect all the way up. That convinced me to look elsewhere. Had it done at a Harley dealer one saturday, they were having a special and doing them for something like $50 iirc, the techs just shook their heads and one said, We've never seen a curve that flat. My buddies' Victory curve looked more like a mountain range,,, https://www.vroc.org/member/t/26766489346604f63d77d7.jpg
Discussion Starter #5
Well thought through. I'm thinking that I might try your 1 cooler plug, just to see what it does to my engine? Thank you.
1 - 6 of 6 Posts
