1 - 7 of 7 Posts
Low Voltage High Current
Can someone with a factory service manual for the vn2000 give me the specifications of the fuel injectors in the vn2000?
The specs should appear to be somewhat similar to this...
Fuel injectors: Type INP– 786
Injection timing 60° BTDC at each cylinder
Static injection quantity 273.1 ∼ 289.4 mL/min
Nozzle type × diameter Two spray type with 4 holes × 0.3 mm (0.012 in.)
Resistance 14.2 ∼ 14.8 Ω.
(above specs are for the meanstreak)
Thanks in advance.
Forgot to grow up
This is what I could find
Make........................Denso
typeXbore.................2 barrel type by 46mm
Static.......................379.9 ~ 403.5 mL/min
Type.........................INP-284
Nozzle.......................one spray type with 12 holes (no diam listed??)
Resistance.................11.7 ~ 12.3 at 20 C
That's all that jumps out and it's late.
Fuel Injectors:Type INP– 284
Static injection quantity 379.9 ~ 403.5 mL/min
Nozzle type × diameter One spray type with 12 holes
Resistance 11.7 ~ 12.3 Ω at 20° C (68° F)
Copied and pasted directly from electronic copy of service manual. A search for injection timing turned up nothing in the entire document.
Discussion Starter #4
SteelMonkey Fuel Injectors:Type INP– 284
Thank you very much guys! This is a big help. Appreciate it! Helps me run down more specifics for that injector.
Discussion Starter #6
What you trying to do... put V2K injectors in a Meanstreak?
Im just doing some homework for planning a future engine build for my Meanstreak.
The vn2000 injectors flow rate is too high and I dont know that they would even physically fit anyway. Just exploring options.
FYI...for those of you with vn2000's that may plan a engine build down the road, your fuel injectors are good for supplying enough fuel for up to around 130hp @ 80-85% duty cycle.
Thanks again for the info!
1 - 7 of 7 Posts
