is any one experienced the following?
driving condition normal road, 55 MPH, engine temp in middle, oil pressure fine, fuel level fine, 5 th gear then for no reason engine stop.
Not lock or seize, just plain stop like ignition was turn off. as i drop the gear down one by one to a stop noticed all parameters normal, bike has power (light, flashing turn signal ect... work....) kill switch is on ... stop at side of the road upset calling a friend to pick me up. tried to start the bike back after checking ignition wiring, power on, fuel hose, vacum hose at the tank knobs( yea got that one before), no luck bike refuse to start. engine turn when starter is cranked but that's all. Decided to stop before i run the battery and overheat the starter. as friend with truck is on his way (about 10 minutes) decided to give it a last crank and she started with no problem.... waited a few minute in iddle as i did not want the engine to repeat that in a busy freeway i was jumping into. all is fine. drove back home n ormally.... has not repeated since (approx 200 miles)..any comment? suggestion? similar experience or recommendation?
thank you.
thank you.
