Hi Captain Caos,
I just installed my hypercharger and I've got a couple questions for you since the instructions I got from Thunder were pretty sparce. And since Thunder makes the adapter, Kuryakyn has no installation instructions for the vn900
I have a few extra parts as you can see in the picture I've attached. The kit came with 3 gaskets, I put one inbetween the adapter and the hypercharger, did you do the same thing? And should I be putting one anywhere else? My adapter kit came with 4 screws, the 3 used in step 8 of your instructions and one smaller one that doesn't seem to fit anywhere, did you get this too?
You say to cut into the vacuum line and insert the T fitting so you can attach it to the hypercharger, but since I have a Canadian model there is no vacuum line. There is a capped openning near the injectors where the vacuum line is supposed to come out of, should I take off this cap and run the vacuum line supplied to it from the hypercharger? Is this what the L shaped fitting is for? If not what's it for?
Right now I'm running it without the vacuum tube attached so the butterflies stay open all the time. The butterflies are also hitting the K&N airfilter when they're completely open, does your touch as well? Its not really a big deal since they can still move around, its just something I noticed.
Thanks for any help you can provide
