Try adjusting the pot settings on the Fi2000R fuel modual. I believe the factory settings are 4-2-0. However, I found out (at least on my bike) if the first setting is 2 or lower than the bike will tend to stall in first gear. I played around with the settings for a while and eventually ended up with 4-2-2. I had Cobra Slashdown pipes, Hypercharger and the Fi2000R. I could be wrong, but I think your fuel modual settings need to be adjusted and that should take care of the stalling problem.
Good Luck!
Captain,
First of all let me thank you for your great hypercharger install instructions. You made this upgrade very easy.
Second thing. I pretty much have the same setup as you did. I have the Cobra longsters, the FI2000 and the Hypercharger. That would make sense about adjusting the pots. I will try that when I get home.
Thank you again,
Bill:-D
