I kept a copy of the Captain's install instructions. Here are the pics and original post.
Pete
VN900 Hypercharger Install Instructions
I installed a Kuryakyn Pro-Series Hypercharger with a Thunder Adapter the other week on my 2007 Vulcan 900 Custom. It's a fairly easy install and should take about 30 minutes to complete. I had the Kawasaki Dealer's Service Department check my work to make sure it was done correctly...and it was.
The Thunder Adapter for the VN900 is Part#40205A (This is a Hypercharger only adapter...please do not confuse it with the other Thunder Adapter for the VN900 (Part#20205B) which is for Thunder Air kits such as the Tornado, Hurricane, etc...
I installed the Kuryakyn Pro-Series Hypercharger Type-A, Part# KA-609421.
If you plan on installing a PCIII and/or new pipes along with the Hypercharger, then I would recommend that a Kawasaki Dealer do the work instead...since they'll have to properly map the PCIII to the Hypercharger and pipes.
Anyway, here are the Step-by-Step Hypercharger install instructions (10 photos)...Good Luck:
If I say its safe to surf this beach Captain, then its safe to surf this beach!
