1 - 7 of 7 Posts
Which cruise control are you using with ISO grips?
Thanks
Happy 1600 Classic owner
I used one on my Honda ACE, with the ISO grips. Just had to remove a little of the rubber from the strip for it to work.
I use the Vista with my ISO's, but I had a modified install. When I put my throttle grip on I left a bit of a space, didn't put it all the way on. I then turned the collar on the Vista around and put it on the grip up to about the end of the chrome ridge, then stuffed the rubber strip in between the collar and the throttle sleeve, from there it was a normal install. Worked GREAT and didn't waste any grip real estate with the collar overhanging the chrome ridge/lip.
Patriot Guard Rider
I have the Show Chrome Comfort Grips with the Vista. I had to dremel out the inside of the ring to make it fit. Works and looks great.
The Clever Lever. It's small,very effective,works great.
I really like mine.....Can't remember where I got it from though.
Maybe from Nopork....
1 - 7 of 7 Posts
