Was working on my 08 VN900 Classic this weekend and was adding a brake modulator. I noticed after the installation that my right turn signal was flashing too fast. I did the usual lamp check on the back and front. Lamps seemed to be ok but I bought new ones and swapped them out. Didn't fix my problem. I checked the flasher and found no problems there. I finally re-opened the right front signal light and noticed that the reflector/bulb holder was loose as a goose inside of the housing. The signals are of course chrome plated plastic and upon removing the reflector I noticed a wire (greenish ground wire) had broken where it was soldered to the back of the bulb socket. I stripped the wire and re-soldered (my son holding the lamp socket with needle nose pliers) the wire back to the metal back of the lamp holder. I then screwed the reflector back into the housing with the help of some blue thread lock compound on the tiny screws. Works fine now!!! I was kinda surprised by the cheapness of the housings and lamp sockets. Maybe this will help someone if they are having the same problem.
Sam
Vibration along with possible shoddy workmanship can quickly break the ground wires in signal housings. You've got to figure the manufacturer will take the cheapest/quickest route for production units out the door daily.
Your lucky the reflector was screwed in. If they could figure a way to "plastic weld" it in they could save the price of the 8 screws for the front and rear light assy. What about .02 per bike?
