1 - 4 of 4 Posts
Hi, My Vulcan 800 classic fell yesterday and now it won't start. I can crank the engine but it won't start. I took off the air filter and noticed that the carburator get flooded. I tried what the manual recommends by opening the throttle to its full position but no luck and crank it with no luck. I checked everything, for loose hoses, fuses, loose connectors with no luck. Please help me.
Yeah, the only thing I could say is its fluded. Everytime I've been down or dropped a bike it fluded but if I opened the throttle and tried a few times it started right up. I'll ask some friends and get back to you.
hello puchy... make sure your getting a spark. then try under normal starting procedure (no throttle, no choke) try a few shots of carb cleaner in the carb. try to start it with the air cleaner off. all i can think of. hope you get her going. good luck.
AZ's Official Mechanic
may be flooded now,may have gas fouled the plugs,
im not sure on that cruiser if they have a tip over sensor or not, if you have a service manual check in there and see. you could check on www.ronayers.com and see if he sells the tip over switch for your bike.
1 - 4 of 4 Posts
