I was having the same problem. As fuel is being pulled from the tank, a vacuum is created due to the fuel vent not letting in enough air, so eventually the vacuum becomes enough to where it overcomes the vacuum in the petcock. A good way to test this is to put an extra key in the gas tank lock, and if your bike starts to quit, pop the gas tank open. If the engine comes back to life, you know you have a vacuum problem in the gas tank. Here is how I got rid of the problem:
1. Ensure that your air plenum (the plastic behind the air filter) is on tight. The bolts on mine had vibrated loose, which allowed the plenum to move, which in turn causes problems in the main vacuum hose coming off of the plenum.
2. Remove the gas tank cap by removing two screws behind the hinge.
3. Disassemble and clean the parts of the gas tank cap as sometimes dust can partially plug the labyrinthe (passageways). Be careful, it's not hard to disassemble, but some of the parts are small and can roll away from you.
4. While the cap is disassembled, take a look at the bottom of the cap. You will see a small hole. This is the fuel tank vent. If you take a closer look, you can see how the spring from the locks protruding out the sides partially blocks the hole. My theory is that the spring blocks the hole enough that air can't flow through fast enough to prevent a vacuum. Take a drill bit and open up the hole. I also drilled two extra holes (one on each side of the center hole) to help with ventilation.
5. Put the gas cap back together and re-install on the tank.
6. While you are at it, take a look at the vent hole coming up through the gas tank. You can identify it by matching it up to a teat on the gas cap at approximately the 5:00 position when looking down on the tank. Take a air hose and air gun, and blow low pressure air through the hole in the tank. You should hear a hissing noise, which is telling you the vent line is open. If you don't look for a bend or kink in the rubber vent line running underneath the bottom of the tank on the RH side.
I did this repair and haven't had any problems since then.
