i have a 1995 vulcan 800 and a friend has a wrecked 99 1500.just needed to know if i can fit a 1500 engine on a Vulcan 800a frame ?and will it work?
Using the 1500 frame, and engine, would the 800 transmission and clutch be compatible?Ummm... I guess the things you have to worry about are this -- if you can methodically break them down -- it might could be done.
Frame-- can it support the extra weight and torque?
Frame -- can it be modified to have the same mounting points?
Fuel -- would you be injected or carbed? -- what engine/tranny combo would you use?
Ignition -- what would your ignition look like?
Computer -- obviously some kind of fuse and relay center plus other electronics if fuel injected...
Drivetrain -- 1500s are stock as shaft drive -- 800s are stock chain drive -- there is a way to convert to chain drive, but I suppose if you modify the fuel, electrical, and frame of the bike, it wouldn't hurt to convert it to chain drive.
I don't think you are just looking at a drop in application -- you're going to have to know how to modify and stiffen... heck -- did you measure the engines yet?
I haven't seen it done -- but if you need to enlarge the frame you have another thing coming -- lol.
I'd honestly say spend the money on a new 900 and you'll get a much nicer bike on what you'd do putting a 1500 in a 800 frame.
Even though Kawi likes to play the cc wars with their bikes by bumping them 100cc's every so often -- it's not all down to cc's. The 800 and 1500 are two different beasts -- you may not like how your bike handles when you put a low down torque thing in that 800 frame.
