I hope that this helps
First you need to locate the oil plug. 17mm. and drain the oil.
You'll need to remove a few things in order to get to the oil filter. 10mm for all
This is what it will look like with every thing removed. The filter can be kinda hard to get off for the first time. Make sure that you lube the seal.
You may need to remove the oil screen. 17mm
This is the order that everything goes.
Put everything back the same way that you took it off. Fill it back up. It took about 3.5 quarts.
It was fairly easy. Took about 1.5 hours. I hope this helps.
