1 - 5 of 5 Posts
They are unique, as they were modern knockoffs of the old British twins. You can get oversized pistons from Wiseco that will take you up considerably, but I would only go what is necessary to clean up the bores because short of installing sleeves which never work that well there is only so many rebuilds available on these older engines before you run out of material to work with.
1 - 5 of 5 Posts
