Parts
Your local dealer should have the parts that you need. Better to get new and KNOW what you are getting than to get something warped and used. The piston, rings and wrist pin and wristpin clips you should get a the dealer when you get the cross hatch honing done on the cylinders...otherwise you will never get the rings to seat and you will just be running oil through the engine...Pistons and ring sets are cheap...even check out Wiseco pistons and rings available through your dealer. They are a personal preference to the stock ones...
