Hello, Just picked up a 99 Nomad a few months ago. Searching seems all I have to worry about is the POG. Thinking about getting a new steel one for 2000 and newer and just welding it on after removing pos plastic gear. Use my mig welder with solid wire and shielding gas. Could get the use of a TIG welder also. Of course will make a cover for behind gear to stop any stray welding bb's from getting where they shouldn't be. I have welded shift levers on my sons moto x race bikes and if I have to remove or split case later the weld can be taken off with a grinder. If heat is an issue (due to seals) I can use a heat dam/sink behind gear. Anyway would appreciate any input from those that have knowledge with gear replacement or welding experience. Is the new kawasaki gear mild steel or cast? Another option would be to drill gear and shaft and install roll pin. Have mounted many gears in industrial settings with alot more stress on them then an oil pump gear should ever see. Will keep posted with pics.
Thanks
Thanks
