Polluter?
I don't know if I can be of any help or not...If you drive, operate or work on internal combustion engines...you pollute, end of story. Increasing an engines HP could, in theory, increase it's efficiency and therefore introduce less pollutants per mile...something a tree hugger could appreciate in a twisted sortof way!
These engines are hand assembled to pretty exacting specs...the more mileage you put on the bike the more seat-of-the-pants "feedback" you should be getting...to a point...getting slower is a spacial thing, you simply are more accustomed to the "power" from 1600 polluting cc's.
Let's look at it from this perspective...Driving a motorcycle as apposed to a car, decreases your individual consumption of fossil fuel per mile driven. Increasing your mileage through modifications could extrapulate into more efficient use of fuel and therefore less-polluting...uh, sortof.
I highly recommend the use of a engine mgmt computer such as Power Commander III. Ahough I haven't checked the air quality at 40 stories...I can say the PC III makes ME feel better!
Changing the air filter system could realize some additional gains in HP and fuel efficiency...Look at several different types. You could change to synthetic motor oil, sometime after break-in. This, in theory, makes you less of a polluter by changing oil less frequently...Although I'm not aware of any "green" motor oils derived from JoJoba or Hemp Oils...but you could check with High Times Magazine or National Geographic on that.
Finally, there are more efficient modes of transportation and they pollute less ie: Vespa...If you're still wrestling with contaminating our environment, I would gladly take that nasty polluter off your hands for say $100.
Okay, I hope this info helped...Gotta run, CNN says Mount St. Helens is about to spew 2.2 billion pounds of particulate matter in the atmosphere...WOW!
