Bike was running fine but the choke was not working so I would hand choke it. Pulled the carbs and found the bowls where the enrichment tube goes was plugged. Cleaned those out and pulled the choke knob rod and plunger to be sure the passage was not stopped up.
Slapped back on the bike and choke now works.
But the dance is not over. Went for a spin and found now I have a hanging slider. :wink: Err...I mean the throttle hangs and is slow to return to idle.
Pulled the tank and checked for air leaks and to be sure the cable was not binding. Cable works like it should and after spraying starter fluid around the intake manifolds and airbox boots and any place air could get in I am finding none.
Did a google search and a couple sites said the pilot jets could cause this. It seems to be running lean at idle because I can put my hand over the air inlet and restrict some air and it picks up rpms. Idle or slow speed circuits clogged perhaps? Pulled the choke out some and the engine races to about 5 grand. But I had to turn the idle screw up to get it to idle so the butterfly is probably open a bit.
I have never seen the pilot circuits clogged hang the throttle. From my experience usually it just stumbles until you build rpms. Mine does not seem to stumble but I now have that hanging curve ball. I do not really want to pull the carbs again if I can avoid it. I thought about dumping some seafoam in the bowls and running that through and then riding awhile to see if she straightens out. I would have to do the slow speed putter so those circuits would primarily come into play. That is almost against my nature....regardless of what zoro thinks. :tongue:
Oh... and I know it is not really a choke but that is easier to type than fuel enrichment every time. :lol:
