I use a Sears yellow jack (with adapter - frame is wider than jack). I leave 2 2x4s under the kickstand and a level on the seat. Let the jack down slowly until the bubble centers.I'm looking for some ideas to keep leveling my V2K.
Yes, I means side to side to check the oil and to wash it, etc.Not too sure what you mean, though. Front-to-back (shock pre-load) or side to side for checking the oil & similar.
And she doesn't complain when you put the kickstand on her? :tongue:I use my wife to level it, usually, though I do have a bike lift if she's not around.
I like this idea, thanksI don't have a V2K but for my bike I cut a piece of wood the correct height that goes under the side stand that makes the bike level...then I have another piece of wood the correct height I put under the frame on the opposite side. Very easy, no cost and easy to store...lol. It makes it a bit easier when filling with oil after a change. For everyday oil check I just hold the bike to check it.
+1:mrgreen:The v2K has no sight glass. It has a very detailed oil checking procedure that can only be done every second tuesday while facing mecca.
And that is way easier then checking the clear radiator fluid tube. Hey, don't get me wrong, I love my V2K.The v2K has no sight glass. It has a very detailed oil checking procedure that can only be done every second tuesday while facing mecca.
Dude, they're virtually impossible to check.......that is one best left to the pros!:mrgreen:Are the muffler bearings hard to check?
How can you not love it?And that is way easier then checking the clear radiator fluid tube. Hey, don't get me wrong, I love my V2K.
Herb
P.S. Keep us posted on that front pulley & shaft issue.
Not cheap but I'm sure your dealer can hook you up. :tongue:Dude, they're virtually impossible to check.......that is one best left to the pros!:mrgreen:
