1 - 10 of 10 Posts
ok i hear all different things from different people! my question is simple, WHAT TYPE OF OIL SHOULD I USE IN THE BOTTOM END OF MY 2000 KAWASAKI KX 250? I've heard to run regular valvoline 10w30 or 10w40, ive also heard to use a special friction oil. any help would be appreciated.
Braaaaaaaaap
10w40 is the same as 80w gear saver/crank oil for dirtbikes. You can buy cheap oil, and change it more often, or HP dirtbike oil and change it less often. I recommend buying oil designed for dirtbikes, not car oil.
ok well i just got the bike a month ago and i live in northern minnesota and the guy i bought it from had it stored outside, i brought it in my house and it started leaking oil, is it possible the seals shrunk? Will they possibly seal back up after the bike has been run for a little bit?
so 10w40 should be just fine to run until i can figure out if the oil stops leaking? if it stops or until i can get the seals replaced i will then switch to the 80w gear saver. thank you for your time
I would go with 10/40w oil gear saver is to much and you still have to change it just as much.
THAT'S BECAUSE IT DOESN'T REALLY MATTER WHAT TYPE OF OIL YOU USE AS LONG AS IT'S FORMULATED TO WORK WITH A MULTI-PLATE WET CLUTCH ! motorcycle specific 10w-30, 10W-40, 20W-50, ATF, expensive "race" oils, they will all work fine...
Just DON'T run thick 80w-90 gear oil, this causes your clutch to "stick"
My hat is made of tinfoil
I use in all my 2 strokes, and in my customers 2 stokes, ATF type F.
Its great............Do not really worry about the brand of it, any quality ATF in type F is fine.
1 - 10 of 10 Posts
