1 - 5 of 5 Posts
What do you call the rubber seal or gasket that is behind the drive sprocket and where do I get one? I've been to a few shops and googled and ebay'd but I can't really pinpoint anything. Where can I get one from is my next question, along with one of those washers that I need to bend over one of the edges so the nut doesn't turn?
That sounds like something you might call it.... I think someone who owned the bike before me probably had the same problem finding it since there was some rubber tubing wound up around the sprocket arm where there should be a pretty thick rubber seal. There was oil and grease all over the place when I took her apart.
I just googled output shaft oil seal and nothing really came up
1 - 5 of 5 Posts
