1 - 20 of 30 Posts
Did my first hard/panic brake today. I had the tail wagging on my little Ninja. My husband and I had our BlueAnt comm devices on and he was saying "too much back brake!!!". I was able to stop OK at the light but you could hear the squealing for miles I am sure. I held it together fine but was a little shook up. Also forgot to get back into 1st so I stalled it when the light changed. Luckily you don't have to be in Neutral to start the 250 so I was able to start it quickly and go. Hopefully, lessoned learned.
Glad you kept it upright, and like you said, lesson learned.
Vintage bike addict
Lot's learned there. Maybe wasn't too much back brake. Maybe not enough front brake. Might be a heads up to practice some panic stops.
Off to see the Wizard!
Glad things went ok in the end. It might be interesting to find a safe place to do some controlled emergency braking and get more 'acquainted' with the brakes with different pressures applied. Thanks for sharing the experience.
There was good practice at the MSF ERC that I took but it was all low speed. I was probably doing 40+ when I decided I wasn't going to make the light. My hubby on the other hand stopped with NO drama whatsoever.
No doubt it is hard to keep our wits about us when excitement sets in. At least you didn't lay it down, good job. Practice is the way to go. Most of us (myself included) need more of it. Do some bikes need to be in neutral to start?
Novice Tank Roller
Keep practicing them. The only way to get better is to get accustom to how to use the front and rear in combination. That way the next time you'll have a better feel for pressure on each.
I remember the first time I experienced that. My rear tire started to slide out and I released it and got a big wiggle when it came back in line with the bike. :)
Stop lights were a pain for me until I started picking a point of no return. I had the same problem as you making quick stops at lights because I didn't think I could make it. Now, when I approach a green light I start thinking about a point where I can no longer stop. When I hit that point and the late changes to yellow, I just speed up a little and keep going. If it is before that point of no return, I'm prepared to slow down. Of course, ya got to be ready for the left turners tryin to make the yellow also.
Practicing moderate speed stops 30-40 mph is also important. I try to practice these stops a least once a week. General start at 20mph and work my up to 40mph in 5mph steps. My goal is to stop as quickly as possible without locking either wheel.
BTW, good job keepin it up.
Discussion Starter · #9 ·
Yes, unfortunately they do, I think it's unsafe. It is not too bad to start and then quickly drop down to 1st but trying to find neutral while you are sitting at a light with traffic behind you must suck pretty bad.
Discussion Starter · #10 ·
Yeah I was wondering if I would have just let off the back brake completely and it started to spin again, if that would have made the control worse. Hubby thought I was going to drop it. I felt the wiggle but I just held it and luckily didn't end up in the intersection. I was mostly embarrassed by the very dramatic squealing noise I was making.
Novice Tank Roller
I've never heard of any bike having to be in neutral to start, unless you don't have the clutch pulled in. :confused:
Novice Tank Roller
Screeching tires always get everyone's attention! :biggrin:
AKA *Kelly*
In the MSF course, during the speed stops, we HAD to shift down to 1st at the same time we stopped or they would take off points. They said in case you have to get out of the way quickly, you want to get in the habit of shifting to 1st when you stop. (Some of the stuff they taught us actually makes sense! Go figure!) :cool:
Glad everything worked out for ya!
Discussion Starter · #15 ·
Normally I do shift down to first but when my bike started to slide I was focused on just stopping without dumping the bike.
Vintage bike addict
Shifting down with rear locked up would serve no purpose any way. Downshifting when braking serves two purposes. #1 so you are in a usable gear if the need to power out occurs. #2 So that you use the engine to assist the brakes in slowing.
Novice Tank Roller
...and we're glad THAT didn't happen! I catch myself in that situation on occasion too. Basically, the last thing I do is start hitting the shifter to get down there. You done fine...for a newbie! :)
glad you kept the bike up and a little shaken up is all that happened.
Practice with a partner, just like the msf, do emeergency stops when you dont know when it will happen, get a parking lot and a partner and have them radomly yell stop no matter what you are doing
if in a turn straighten up and apply brakes.
The more you practice it the better you will feel when it really happends.
I had one bad emergency stop situation - it was going to be a hard stop. I did it perfectly - Not too much rear brake, jsut the right amount of front, came to a stop, car behind me barely stopped but did, then BANG within 2 seconds I got pushed by the guy behind me cause he got nailed by some *&^%$ on a cell phone
lesson is, have eyes everywhere and be ready to move
As for bike starting with neutral only - might be true - but its VERY unsafe. I too have never heard of such a motorcycle ... does that mean only the electric start or can you not start it in gear even if you roll start it?
I had an ATV that would only start in Neutral - I overrode that wire and made it so it would start in any gear - but before that - it could still roll start in any gear
kenny
Patriot Guard Rider
My Yamaha V-Star Classic is like this....and they always have and still are like that as far as I know.
Wont start unless its in neutral.....clutch does NOT have to be pulled. If you put it in a forward gear with the kickstand down it will die.
I would disable it in a instant if I knew how.....its annoying as hell.
1 - 20 of 30 Posts
