VERY ACCURATE
The absolute time to change over to synthetic oil is when your graph of gas mileage reaches a plateau, mesa, table, flat spot and it has effectively leveled off. then you should change over to pure synthetic. If you want to be thrifty, no matter what oil you choose to go with remember that the filter is the object that fills up with all the "stuff" in your oil. IF you were to just change the filter and top the oil off, you would be effectively changing 1/3 of your oil when you do it. IF it makes yo feel good to drain and change the filter both then go ahead. but if the ris a one or th aother then do the filter not the oil...the filter holds all of the contamanents...dust, metal, whatever gets into the engine...
You should, if you are very serious about your bike keep records mileage date, what was done, changed, bought , utneups, spark plugs, oil filters, yo may find that you actually get better fuel economy with differrent fuels, and as funny as it sounds even oils and filters...air filter cleaning and OILING is very important, changing the windscreen on a sport bike to a taller one should result in better fuel economy...tire pressure is VERY important to chnage and find the right pressure for your bike as well...
