1 - 6 of 6 Posts
2006 Vulcan 500 LTD
Can someone please tell me exactly which is the coolant drain bolt on the Vulcan EN500? I know it's on the bottom of the water pump cover but which bolt, there are many. Thanks
My hat is made of tinfoil
Its as easy or easier to pull the hose off......and then inspect the inside of the hose while the end is pulled off.
You can tell a lot looking at the inside of the hose, and also squeezing them, feel for spots that just feel different.....maybe too soft or something.
If they are suspect, change them.
I like to use silicone hoses myself.
Dunno if your 500 is similar to my 500, but mine has the drain on the right bottom of the pump. It sits out farther than the others.
Brian
1 - 6 of 6 Posts
