1 - 9 of 9 Posts
other than the fact the bike weighs a ton are you sure you don't have a caliper dragging the brake pad? If you were turning at the time it could be an adjustment or your legs are wimpy going backwards? :) :confused:
If you raise the bike on a stand and turn the wheels do they drag?
it must be bike weight and my height mixed together. i am short enough that i have to tip toe pushing back. **** bad genetics :grin:
Brake dragging, chain needs adjustment, wheel bearings are bad, tire pressure is off, back wheel isn't straight. But if you're a real bad a** then I'd say that it's in gear.
His tire would drag if it were in gear and playing he-man, but hats off if that was the case!
1 - 9 of 9 Posts
