I just did my first oil change at 600 miles. Leaving aside the fact that the factory application of the filter was WAAAAAAY to tight, I found a wierd little clamp on the filter. Its a metal band that can be tightened or loosened, and secured to it is a rubber prong. The prong has to slide between two other prongs that are mounted right above the threads for the filter on the engine block. The only purpose I can see for this is a safeguard against the filter accidentally coming loose while riding. In a case like that, the prongs would prevent the filter from turning at all.
Personally I think its overkill, but I wanted to ask those more experienced than myself. Given my ability to tighten a filter down like a normal human being, can I just remove this wierd clamp entirely? I ask because getting it on and off requires a great deal of effort with a small allen key.
Thanks
Thanks
