Hello All Fellow Riders....
I have a 2007 Brute Force 750i. Ive had it since it was new. The summer of 2009, I had to replace the wiring harness, the CPU, and the EBS servo. These went well ,all was fine...until Sept of 09. Without warning, I went to start it...nothing! I could pull start it..but the speedo pod was flashing and the EBS servo kept tring to cycling like it was being turned off and on.Also when I appilied the brake the pod would go out. The speedo was not accuate as well. The key gets notthing. No lights no diplay. This lasted a while, then I would try the key and it would work, puzzling indeed????? I have tried the battery...a solid 12.5 volts. I tried the grounds...they are tight. I have tried finding a broken wire....HA HA HA!!!! If I can get any suggestions it would be much appreciated. Thanks in advance.....JIM
