1 - 5 of 5 Posts
I have a 90 kawasaki zr550. Once I fire it up everything is normal. Once I drive it a bit, things start getting a little funky. The RPM's start dropping off when I'm sitting at a light and I'll have to give it gas. When I ride it starts sputtering and getting really chunky. But when I'm gunning it everything seems alright, seems like less power though. That's the best I can describe it... Any help would be stellar.
Cheers,
:hohoho:
Jason
Easiest would be to put a new set of plugs in and check all leads and caps are connected tight. Check condition of airbox-rubbers and inlet manifold rubbers too.
If this don't help i'd get your valve-clearances checked m8.
While you're at the servicing check carb cleanliness and settings or if not able run some carb cleaner through in a couple of tanks of petrol.
Keep us informed :smile:
PS Check brakes aren't getting hot when the trouble starts ;)
great thanks, now that I think of it my manifold nut was loose for about 100 miles and I had a pretty severe exhaust leak out of the 3rd cyl. I've heard that could foul plugs so I'll change the plugs and see if that helps!!
Put in new plugs and drove a few miles, seems to be working just fine!! Thank god...
Thanks for the advice Green.
Now I'm leaking oil from somewhere!! Always a new problem :(
1 - 5 of 5 Posts
