I have problem with my 1997 zx-6r. The bike was crashed (slide - right side plastic parts, scratches on clutch covering, ...). After that, the engine doesn't start. When I press start button, the engine is turning, but it doesn't start.
What could be a problem?
Thank you for your answers.
CHECK
Are you getting spark to the spark plugs?... I'm not sure about the EFI, but check to see that when you remove the gas line from the tank that you are getting a gas flow through it. Let us know if you have spark...
AZ's Official Mechanic
if i remember right that bike has a tip over sensor. get a manual and it will tell you how to reset it.
dont remember if that year is FI or carbed ? if its FI then the above statement is prob. your best bet unless you trashed some electrics.
if its carbed then i would say you more than likely GAS FOULED the plugs while it was laying on its side. check to make sure you dont have alot of gas in your oil also.
