Hey all, i'm new here and this is my first post
. Anyway, I noticed a while back when i started my bike (it sat for about 6 months) it gave off a sound much deeper then normal. It almost sounds like a Ducati. It idles fine (with the exception of the deeper tone). It even runs but kinda ruff. At higher speeds seems to want to hesitate a bit. I've changed the battery (old one was dead), replaced the spark plugs, drained the tank, cleaned the fuel filter (the small one at the carb as well), and even pulled the carbs out and emptied them. I cleaned them as well but i did not actually mess with the floats, just used a bit of spray to clean the outside and inside.
I put everything back together but nothing has changed. Does anyone have a clue what else I can try? I've herd about possible carb sync'ing but the bike is a 2000zx6 with "only" 6500 miles. I'm shocked i even have a problem as it is, the bike is babied.
Any suggestions would help. Thanks
