1 - 20 of 36 Posts
ZX7 Starting issues
I can't get my 1995 ZX7 to start, haven't been able to get it to start since mid summer of 2007.
I stuck a few wires and a switch on the solenoid to just override whatever the problem was, and start the bike. Worked pretty well, except taking the seat off every time I want to start the bike got kind of annoying.
Well I've recently started to work on getting it fixed now actually (along with fixing cracks and scuffs, and repainting), and I thought back in the summer it might be the junction box.
Main problem..
I put in the key, turn it to to the "ON" position, hit the start button and it clicks. Starter doesn't turn or anything, just a clicking sound comes from under the seat.
I thought at first it was the junction box...
Today a new junction box from an '03 ZX7 came in the mail off of eBay. No luck... Still same old clicking sound.
Picked up the igniter as I pushed the start button and the clicking seems to be coming from there, I could feel the click pretty much.
My first assumption is that the igniter is no good....
My second thought is (more or less a question)... Does anyone know of a way to test out the igniter / if I bring it to a mechanic would they be able to hook it up to a computer or something to see if it's ok?
Last one(s)..
I'm seeing some after market stuff out there, along with having lots of problems trying to find a replacement one if that is what is in fact broken.
Can I use a different model does anyone know? Or is there a cross reference chart out there that I can look at or get access to?
Any and all help is appreciated...
EDIT: Title change Dec11.2007
By ignitor, do you mean the starter solenoid? If that's what's clicking, yes, it's bad. I don't know exactly how to wire around it to make it start. But I would say your starter is bad.
No, not the solenoid, I've been told by a few shops that the solenoid is fine...
Part number 21119/A
(Computer, ECM, ECU, igniter, whatever you wanna call it)
Oh, the brain! Yes, it controls just about everything. It is hard to test them, and I know they cost an arm and a leg. Will see if any other years will fit. I'll be back!
Tried '97, but didn't match up. Call your Kawi dealer Tuesday, and ask them to put that part # into the "where used" feature on their microfiche. There may be more matches.
Talked to the local Kawasaki dealer and they said if the igniter/brain was no good, the bike wouldn't even run.
.... :| :confused:
Back to the drawing board I guess.
Discussion Starter · #9 ·
If the solenoid was shot... would I still be able to jump the connection between the two bolts on the solenoid and make the bike start?
When I have everything hooked up, I push the start button and the bike makes a click and whurring sounds, like its trying to make the starter go, but it doesn't have enough power...
Any ideas?
I think it's the junction box. I know there is a thread telling you how to wire around it. We did it on the '93 ZX-11 here at the house.
Try these #'s.
26021-1077 JUNCTION BOX
26021A 26021-1089 JUNCTION BOX
Discussion Starter · #12 ·
Already replaced the junction box with a newer one from an '03 ZX7. No luck :(
Wire around it?
Yes. I will ask how do this, and get back to you. Give me some time.
So you replaced the junction box, and the ignitor box?
Discussion Starter · #15 ·
Replaced the Junction box, but I was told by the local Kawi dealer the igniter is fine. If it was no good, the bike wouldn't have ran the times that it did.
Without the bike being in front of me, I can't tell you how to wire around the junction box, I can only put up the pics of the one we did.
He replaced his with a new junction box also, but ended up having to wire around it.
Discussion Starter · #17 ·
Is it just that black wire that is the modification, and do you know what it is bypassing?
Yes, just the black wire. I wish I could be of more help, but the guy that did this is stuck with no internet at the moment, or you would have had it running by now!
Discussion Starter · #19 ·
lol, No worries. I have a few things I'm going to try and do to it today. I was told to just check the solenoid again (using a multimeter) because it doesn't sound like the junction box, igniter, or any of the other sidestand / neutral / clutch switches.
Worst case scenario, I bring it in to get it worked on, right? lol
It jumps the starter relay. It would be advisable to have a wiring diagram before you do this. Just don't go sticking jumper wires wherever.
1 - 20 of 36 Posts
