hi guys, ive got a 93 zzr600 e1, recently changed the clutch and sometimes its a bit of a pain to get into first gear when coming to a stop at junctions etc just wondering if this is normal and just a case of me not being used to it yet or do i need to have a bit of a fettle and adjust the clutch.
it goes into first no problem when starting off on a ride and changes up and down through the gears no problems, its just getting into first some times, it doesnt seem to have that 'clunk' feeling if that makes sense.
Did you oil all the friction-plates on the clutch before assembly and change the oil?
If it all clunks in first off and goes up the box ok then i'd think the clutch-adjustment were ok. Check you've got a couple or three mm of free-play at the lever and the lifter-arm down on the casing is making an angle of less than 90 degrees.
I'd have a close look at the gear-change linkage m8, it might sound daft but
could just be the splined link connected to the change-shaft is not quite tight enough or slightly mis-positioned (away from the vertical).
I'd also have a look at the pedal-pivot, undo, clean and regrease 'cos i've seen these getting crudded-up and folks thinking their gearbox had gone :)
I'd take a few minutes playing with the adjuster-rod ont linkage to set it just right for you and your old-boots, makes a fair old difference that.
Obviously try to be down to 1st-gear before you stop at lights/junctions etc, don't try shifting down whilst sat.
Sorry if it sounds like i'm spouting the obvious to you :wink:
just took it for a little spin and it seems to of fixed itself :confused:
but we did oil the plates as we should, spent some time making sure the cluth was correct, and that all the linkages moved freely etc so i think it was just a case of no being used to it i dont know, cars and bikes have a mind of their own
