05 750 Brute Force spraying oil out
12K views 6 replies 5 participants last post by  imported_cookie_monster
#1 ·
I have a 2005 750 Brute force. This past weekend while riding the bike
(30mph) sprayed out around a litre of oil out. I can't find exactly where it came from but its looks like the right front of the airbox. The oil sprayed out pretty hard, not just a trickle.
Any suggestions??
Thanks
#7 ·
2007 Brute Force 750. I had the same problem last night. Had about a 15 mile road ride home. I was hitting it pretty hard most of the way. Almost home, oil started spraying up from underneath the airbox somewhere. The temperature gauge flashed a few times also. Would overheating cause this? Or do I need to look for a hose leak? The bike seems to still run fine. Thanks
High oil temp. There shouldn't be any oil spraying out anywhere unless one of the hoses is off of the air box. The crankcase vent hose is attatched to the airbox and then there is a little "nub" hose thing (for the lack of the correct terminology) that can come off/leak oil out. High oil temp causes the oil to break down, and it's more likely for the "thin" vapors to build up in the airbox. High oil temp will also help lead to the coolant warning light to come on....and also leads to torn up engines. It's a known issue with the V-twin kawi's-and is exactly why it's critical to keep good, clean oil in the motor-and change it often. Or put an oil cooler on it if it's not already too late. Good luck.
#6 ·
#5 ·
If this is the one I remember, it turned out to be a broken piston from laying it on its side and not removing the spark plugs to blow the excess oil that ran into the cylinder out before attempting to start it again.
#2 ·
Check the oil tube that is located between the head and the crankcase. It is below and in front of the air box, and if one of the O-rings fail it will spray oil on the air box.
Also, check inside the air box for any excess oil that may have sprayed out of an overpressurized crankcase, and in through the crankcase vapor lines. If that happens it can be from a broken piston ring, a too tight exhaust valve, or from an exhaust restriction.
Better yet, I could take it off your hands for a hundred bucks if you are fairly local!
