Hey all. I have a bunch of firsts for ya!! This is my first time here (Hello everyone), I just got my first Kawasaki and the 1978 KZ650B is my first ever bike (minus my motor cross bikes back in the day). Big day for me, huh? :biggrin: Ok...On to business...
This KZ650 of mine has a bad head (I believe my dad said it has a hairline crack in it). It runs well enough when its cold but after about 15-30 minutes (as she warms up), one cylinder leaks. I'm not sure which cylinder number you want to call it but when you are sitting on the bike looking forward, its the second cyclinder from the far right. Anyhoo...It turns out that the head needs to be replaced. I have a few leads on heads, one being from a 1980 KZ650. I assume that these heads didn't change much over the 3 years? True or false? How about the camshafts? Are the cams in the 1980 interchangeable with the 1978 KZ650?
Another thing...This bike was my father's and he diddled with it a little bit (I think mostly because thats what old retired men do - they fiddle and doodle). He said that he was inside working around the timing chain (for whatever reason) and said that there are four "risers", two on the top and two on the bottom of the chain that he fooled around with (again, for whatever reason). In the end, he ground down the top two "risers" thinking that he was doing something fantastic and then later felt that he made a boo-boo by doing so. Does anyone know what he might be talking about? He explained it to me, and though I am mechanically minded - I couldn't follow him. I looked at a schematic of the chain and surrounding components and it didn't help. For those of you who might know what he is talking about, do you know the actual name of these "risers" (what he called them). I'm not sure exactly what they do...If I knew the technical term for these parts I would just go ahead and order 2 new ones right off that bat.
All in all the bike is in pretty nice shape. I know it needs a camshaft. Though the camshaft operates the engine well, the end of the cam which runs the tachometer is pooched. This means the tach doesn't work. I think the old man said that the camshaft had a gear or splines or something on one end which drove the tach. I have yet to get the bike home (tomorrow's project) and as a result I haven't got it open yet.
Being my first bike, does anyone have any advice for me as a cycling beginner? Take into consideration that I'm 5'11" and 155 lbs. I pushed it around the loose gravel driveway for about 15 minutes and had to manuover it around a pile of obsticles (dad's yard is full of what he refers to as gold - I'm sure you can picture it) to get it to where I needed to get it without too much strain. Would you consider this bike a fair beginner's motorcycle or not? Is there anything I should keep an eye on (mechanically) with this bike? Does it have any qwerks or known defects?
Thanks all in advance for any help, suggestions or comments you care to share. And HELLO again!!
Cheers!
- Dan
Cheers!
- Dan
