i have a 1994 zx750L ninja had motor replaced with a 1995 zx7r. put new battery in, bike starts sounds real strong. when you ride it the bike will get about 4 blocks then shut off. you then restart it and it will ride a while longer. if you are going fast shifting between 1st and 2nd gear it will shut off more often then it would if you would stay in 1st. i was told the carbs were jetted it has a muzzy exhaust, fuel pump was replaced. the temperature gauge is not connected found the loose wire and had it working temporarily is this part of the problem if not do you have any idea why it shuts off but everytime it will restart and continue to ride? This bike is for sale on ebay and craigslistchicago.
