I am installing the heater on my 2000 Mule 2510 4x4 (kaf620-A6).
Everything I have learned about working on my mule, I learned from this site. I have been reading about changing the coolant and bleeding out the air, and for the first time, I almost want to bring it into the shop to get it done. I am worried about making a mistake and overheating and warping the heads. I don't want to learn the hard way...
I understand the process, and will even jack up the front end, but now after reading the service manual and it tells me to remove the torque converter to access 2 bolts for bleeding, I feel like the job is getting to complicated. (besides, I don't have a puller for the torque converter).
Do I really need to get to those bolts under the torque converter?
Also, I had it idling yesterday to see how long it will take the fan to go on so i can compare when I am done bleeding... It was about 55 degrees Fahrenheit, I let it run for over an hour and the fan never came on! (Is this normal?) I started to get nervous, but I hear it come on all the time when riding. I was riding it again after the Idling test, and it did come on as it should. Is this normal to not come on when Idling? I swore I was smelling antifreeze like you would if you overheated. Sometimes I feel like I smell it while riding but not very much. It runs great, doesn't seem to overheat, the temp light never comes on (i checked the bulb and it works).
Due to installing the heater, I have to figure this out. I have read the recent threads with information on this but not about the time it takes while idling for the fan to go on, and nobody mentioned having to take off the torque converter.
Thank for any help.
Joe
PS: Glad you guys are enjoying the recent slide-show I posted of my Mule progress. I will add some videos of me having fun in the snow if you help me with the heater.
My Kawasaki Mule Project - YouTube
Thank for any help.
Joe
