I first posted this on the Mechanics corner, some reads, but no comments.
I have an 88 Bayou 300. Starts instantly but the carb continues to overflow gas on the ground, It does run good, but leaking gas is a nasty problem. I bought a moose carb kit, changed everything. got some improvement when I put the original float needle back in. set the float about 20 times, trying higher and lower. Then spent the money and put a new float in. The float needle seat is not replaceable on this Keihin 32CVK. I also seem to have a problem with the carb bowl O ring gasket. They seem to swell to a larger size and do not seat to seal the bowl which could be contributing to the leakage from the overflow. a new carb is about $325. I would hate to buy a used carb over $100 on ebay only to find the same problem. I own a sizable collection of old bikes and setting float or changing the needle and seat has never been a problem.
Has anybody switched to a 32mm Mikuni Carb and what jetting did you use. I really think the Keihin is a poor design especially because the seat cannot be changed.
this problem has been going on for 3 years and I am frustrated. I get the impression this problem is very common on the 300 bayous.
