Hello,
So for about the past 2 months my Ninja 250 has been dumping gasoline out of the overflow in between the two carbs. After trying just about everything to fix the carbs and the float bowls, I decided to buy a new pair of carbs.
Guess what... same problem. When the engine is running, the carbs dump gasoline.
I then discovered that with the fuel switch off, the carbs stop dumping gas, but then start again when the fuel selector is turned to on. This led me to believe that maybe the petcock was damaged and forcing gas into the carbs, so I opened it up and cleaned it real well, but no change in the problem. And I also tried allowing air to escape from the tank to make sure there wasn't a pressure buildup, but that didn't help either.
What could possibly be going on!? I've totally run out of ideas.
Thanks,
Jess
Thanks,
Jess
