clutch replacement
620 views 1 reply 2 participants last post by  RCW
#1 ·
I changed the shift forks on my bike. put clutch back in and everything put back. Fire it up and can feel it try to pull but will not move from there. can someone tell me the rite way to install the clutch. its a 2000 zx6r j1
#2 ·
Most often when someone brings one if for clutch engagement problems after changing clutch disks it is a matter of parts in the wrong order or the release mechanism being incorrectly adjusted.
Go to Kawasaki.com and follow the Owner Info link to the parts diagram and make sure everything was installed in order shown in the diagrams. Then adjust your release rod nut exactly according to the procedure in the service manual.
