Dual disc from for 78 kz650
3.4K views 5 replies 3 participants last post by  martin-csr
#1 ·
I have a 1978 kz650 and want to upgrade to dual disc. Is this possible? The front fork looks like it had the setup. What do I need? View attachment 66354
#2 ·
I understand, your present master cylinder will be too small for the amount of fluid needed. You will require either a spliter hose to power both calipers, or a longer "Banjo" bolt, so individual hoses can be used. If you can get a hand powered vacuum pump(I use a brand called Mityvac), it will make brake bleeding easier. Also new bleeder bolts, on the calipers, with the built in one way valves.
Brake Lines
http://www.galferusa.com/html/ss_line_kits.html
Inline tube The brake plumbing experts
Spiegler Performance Parts - Motorcycle Brake Line Kits
HEL Performance USA | Stainless Steel Braided Brake Lines
http://www.russellperformance.com/metric_two-line.shtml
http://www.goodridge.co.uk/motorcycle-brake-lines/kawasaki.htm
Galfer Brake Lines
Brake Line Bleeders
Speed Bleeder Sizes
Motorcycle Application Chart
Pingel Enterprise, Inc. ? High Quality Motorcycle Performance Products
Spiegler Performance Parts - Speed Bleeder | Motorcycle Brake Bleeding
#3 ·
If you go with the popular Stainless Steel Braided Hose, be careful, as it will act like a slow speed file, cutting through paint, wiring, and other tubing and lines, as it wears away. The best brake lines have a heatshrink coating, but black spiral wrap works good for this too, and can be found at most electrical supply places, and some hardware stores.
#4 ·
Thank you. What about the disc and caliper?
