Bridgestone does not make the RWL in the 110/90-18. I looked for it. The 120 is calling for a 2.5-3.0 inch rim, the 110 calls for 2.15-3.00. The 120 tire is rated at 5" wide and 26.5" diameter on a 2.50 wide rim, where the 110 is at 4.4" and 25.9" diameter. If you insist on the Bridgestone 120/90-18 RWL be aware you may also run into fender clearance issues due to the size difference. That was the same size tire the GL1100 GoldWing ran (I know, I had two of them and went down in front tire size on both, to a 110). You could take your chances on the 120, but I'd be measuring the tire on the bike in width and diameter to be sure the 120 will fit. If it was me, I'd just do black walls to have the right sizes, having done the oversize and undersize changes and reading what you want.
I will mention
Dunlop does a RWL in a 110/90-18 in the F20 model, which is an OEM style replacement tire.
You may end up with less rubber on the road with the 120 since it possibly will pinch up on the same size rim as intended for the 110. That might cause more tracking issues. Even if it doesn't pinch up it will slow steering response significantly. In neither case will the 120 give you any wear advantage to speak of. Go with the 110 since it is what the bike was designed to use. It will handle the best for your needs. It's incredible what just that little bit can do either up or down.
