metal pad on motorcycle parking
1.9K views 13 replies 12 participants last post by  zedx11
#1 ·
Has anyone else heard that it is bad to put your kickstand on the metal pad in motorcycle parking? I've heard that it can drain your battery. I just moved to a different building and my kickstand sinks into the asphalt here so I put it on the metal pad.
#3 ·
i'd say that is a possibility if that metal strip is not grounded? get yourself a pice of wood or buy one of them purpose built stand pucks
#4 ·
Yea I plan on getting one the next time I'm at the shop. Today was the first day I rode out to this office and it's a scorcher. My kickstand had gone into the asphalt about 1/4 of an inch. I moved it to the pad.
#6 ·
I use a squashed aluminum can. Works fine. This is the first I've ever heard of it damaging anything- I think it's a crock of......
#7 ·
Myth.
Electricity doesn't magically bleed off into the ground.
It is suspected, but unconfirmed through testing, that the OOOOLD rubber-cased car batteries could drain when placed on damp concrete. It is absolutely not a problem with modern plastic-cased batteries, though the myth persists.... why?
Joe puts a battery on his garage floor, and 6 months later it's dead.
Duhh. It'll be dead in 6 months no matter what he puts it on.
Aircraft are required to be electrically grounded when they are parked.
You used to be able to buy grounding straps for auto's to hang from the suspension to prevent a static shock.
Think about it... your kickstand is metal.
When it's down, it's resting on the ground.
The plate is metal. Put the kickstand on it, and you simply have a bit more metal between the frame and the ground... it is no more or less grounded with or without the plate...
But even if the plate were electrically grounded, you need two contact points to complete a circuit (thus, draining power).
Use the plate.
