Need help ZRX 1100 fork seals.
6.7K views 4 replies 3 participants last post by  Alf
#1 ·
Fork seals are leaking on son in laws bike and we decided to change then out ourselves:( :( :( . Everthing went without a hitch until we tried to remove the bottom end damper allan bolt everything just turns. I reseached fixes but seem confused by some of the special tools how can you put one down the opposite tube end when there is a rod sticking out. Duh not feeling really intelligent today. We did a lot of research before tackling this.
#3 ·
The Kawasaki Special Tool is C in the centre pic.
It's basically a tube with a Hex driver one end and a square on the other end, You remove the nut from the end of the damper tube and slide the tool down until it locatates at the bottom then attach a spanner 24mm i think on the other end and with an allen key on the bottom of the leg you undo !!
The pic is a ZRX1200 but the 11 is the same ..
