what do you mean by "fit wider wheels"? This is my first bike. Shoot me straight- I want to put 120 on the front and 140 on the back. Is this a good move or not? should I just stick to the stock sizes? Also, what brand tire would you reccomend? I have seen lots of good stuff on BT45 battlaxes.
Go to the
Bridgestone site, click on the Battlax BT45 product in the window at the top. Then click on the "details on this tire" button at the lower right corner of the page. You will find the 120/70-17 fits a 2.75"-3.75" wide rim and the 150/70-17 fits a 4.00"-4.50" wide rim. Look on your rims. If they are in those ranges and there is fender clearance the tires will fit. If the rear is a 3.50 you can fit the 140/70-17 on it.
Now what will happen if you can actually fit them is your steering will become significantly slower than stock and will take more effort to turn into corners. If you can tolerate that, fine. Just be forewarned of the consequences of going bigger. Personally I might consider the 120, but I guarantee I wouldn't do the 150. The wear won't be much greater if any and it just takes more power to spin the extra weight. I'd consider the 120 just to have more foot print under braking, but would probably raise the forks in the triple clamps to try to compensate for the change in ride height and steering quickness. But that's me. I have an idea of what I would want and how to get it.
My bike has a 110/70-17 on the front and a 140/70-18 on the rear right now and I plan to go 120/70-17 (or 120/60-17) with possible raising of the fork tubes in the triple clamps on the next set of tires, but will stay with the 140 on the back for the extra performance and quicker handling. I may change to a wider 17 on the front and rear to enable me to use radials, since I have the wheels sitting in the garage. Like I say, I know what I like and want plus I know how to get it.
If you like the quickness of handling presently with your 500 stay with stock sizes. If you're going for a look, have at it.
